Does anyone know how the closed position of glass door can be adjusted. On one of my BS9000 its not parallel to the aluminum base plate, i.e.about 3 mm to low in the front. I have seen this issue a couple of times so I guess its a known problem,- or?
Open the Aluminium plate to the Control Panel. There is a small hole on the left side where you can put an imbuss inside to adjust.
on the other side you have to remove the aluminium plate. There you can see the hole too.
Is this the hole that is set in an angle ("downward" toward glass door)? Looks a bit like the socket on a Fender Stratocaster, if you know what I mean?
Yes, it's that one.
Hi Mate I have the same problem with my Bang & Olufsen 9000 and the glass door is a little off line, slightly touching the CD arm… did you resolve the problem with adjusting the screws??
