Beosound 9000 mkII power plug broken
This post has 5 Replies | 0 Followers
Rasmus
Seattle
Posts 8
Rasmus Posted: Thu, Oct 28 2021 4:07 AM
Hi, I have a beosound9000 MkII where the power input plug has been torn out. The wires coming out of the unit are the same color and size and cannot be told apart. My question is whether it matters which side of the plug i solder the wires back onto ?
thank you in advance
leosgonewild
Helsinki, Finland
Posts 2,373
Just buy a new one.
It is removable.
Rasmus
Seattle
Posts 8
HI, it is not the cord it self that is broken. it is the plastic plug end that is built into the unit that tore out (and wires disconnected from it).  i need to solder the wires back onto the power-in plug... click on picture
Beouser66
Posts 47
Beouser66 replied on Sun, Oct 31 2021 8:51 PM
No it doesn't matter
TWG
Posts 1,672
TWG replied on Mon, Nov 1 2021 8:11 AM
As far as I know it's a standard euro C8 socket like this:
https://www.sweeta.com/iec-60320-c8-socket-inlets-c8-swhjc-033.html
You can get them on every electronics store. The servicemanual should state which kind of print socket it is (mounted on the circuit board or mounted inside the casing etc. ... different variants are availabe).
Rasmus
Seattle
Posts 8
Rasmus replied on Mon, Nov 1 2021 10:52 PM
Thank you!
Page 1 of 1 (6 items) | RSS
