For years now, the door on my Beosound 4 opens, to start closing a second later. One has to be quick to put or remove a CD.
Any idea what may be causing this?
Thank you lawrencejmcook 🙂
It opens and holds when I present my hand, it is when I press "Load" that it opens up fully to close readily, unless it decides to stay open as it should. Do you still think that it is belt related?
