Temperamental Beosound 4 door
yahoe
Posts 4
yahoe Posted: Sun, Dec 12 2021 2:50 PM
For years now, the door on my Beosound 4 opens, to start closing a second later. One has to be quick to put or remove a CD.
Any idea what may be causing this?
lawrencejmcook
Posts 742
Needs a new belt, maybe? The belt might be slipping.
yahoe
Posts 4
yahoe replied on Tue, Dec 21 2021 9:06 PM
Thank you lawrencejmcook 🙂
It opens and holds when I present my hand, it is when I press "Load" that it opens up fully to close readily, unless it decides to stay open as it should. Do you still think that it is belt related?
Duels
England
Posts 2,553
Duels replied on Tue, Dec 21 2021 10:23 PM
I’ve heard of this fault with the BS4 a few times. My father’s BS4 had it. Powering the unit off completely and turning it back on it again (after about 15 minutes) worked, although the issue did recur some time later. I don’t think it’s mechanical. More likely to be something to do with the firmware.
Page 1 of 1 (4 items) | RSS
