Beosound 1 flashing rapid red
This post has 4 Replies | 0 Followers
liviu_o
Posts 157
liviu_o Posted: Fri, Jan 21 2022 10:18 AM
Hi all! My BS1 is flashing rapid red and trying the reg stuff as updating, cutting power chordBig Smile, etc doesn’t help.
Anyone else in this situation?
Any ideas beside taking it to the dealer?
Raeven
Posts 61
Raeven replied on Fri, Jan 21 2022 10:25 AM
Was in same situation unfortnally the only solution was taking it to te dealer. He send de Beosound 1 back to factory and they replace the motherbord.
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jan 21 2022 12:35 PM
I had that problems occasionally. Most times I have been able to power cycle the unit and it was okay after restoring again.
Aussie Michael
Melbourne, AU
Posts 3,730
liviu_o:
Hi all! My BS1 is flashing rapid red and trying the reg stuff as updating, cutting power chord , etc doesn’t help.
Liviu_o,
How did you go?
Did it work itself out? Or Did you take it in?
If I recall mine flashed red when I was connecting it back to a new network. Have you tried the setup button underneath and try to set it up from scratch again?
James1980
Posts 80
James1980 replied on Tue, Jan 25 2022 8:55 PM
My Gen 1 BS2 did this a while ago, connecting it via cable to the router when setting it up again did the trick. Give that a try.
Beovision 10, Beoplay V1, Beolab 17, Beolab 9, Beolab 4,  Beosound 2, Beosound Moment x 2,  Beoplay M3, Beogram 1700
Page 1 of 1 (5 items) | RSS
