Eclipse 65V1-32Beosound M5Essence MK2BLI
3.0.40943.163635848
Eclipse 55 MkII here
Eclipse Mk1 55
Software Version 2.7.37196.117795280
(Not sure if there’s any regional differences, but based in the UK)
Matt:Eclipse Mk1 55 Software Version 2.7.37196.117795280 (Not sure if there’s any regional differences, but based in the UK)
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Hi, it might be an issue with your BeoRemote.
It has happened to me a couple of times before. Just pull the batteries out and put them back. This will force a new pairing (done automatically, according to the instructions my dealer gave me back in the day) and the Stand option will be in the List again.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
I don't know if this helps but it talks about having to re-calibrate the stand after moving the TV (Moving = unplugging I assume)
Link
Stoobie
With the older TVs there was something about having to plug the stand in either before or after powering on the TV. I had the issue with an MX 8000 and I'm almost sure you had to plug the stand in after powering up the TV for the stand to be recognised..
So long ago I can't remember.
Did you ever get this resolved?
its the dsse board in soundcenter thats is faulty
you can check that in menu service advance diagnosis
if 12v is 0 and red its dsse board
but to the connection of stand no matter of model
the stand cable have to be connected then tv is
unplugged from power otherwise the stand
never be recognize
