Hello - as anyone experienced problems with a copy CD on either the 3300 CD player or the CDX2 player. I made a copy of an old CD of mine to preserve for my use only and neither system would play it??
Is this a normal practice with B & O units that they don't play copies or is it just my two units don't like copy CDs made on my computer?
Many thanks
David[^o)
Professor David A Flynn JP LM
Hi there, I have a Beogram CD 4500 and it will play anything
My CDX will play anything.
It often helps if you don't burn the CDs at the maximum speed. Otherwise, CD-Rs should play with most any CD player, CD-RWs can be a different matter.
--mika
The RW's don't play on a BG-CD4500.
Double-post... Yet again.
Jacques
All my old CD players - even the CDP-101 and the CD100 - will gladly play CDRs but not RWs obviously. However I was able to play one with my CD3300 by going directly to track 2.
We mustn't forget that the recordable CD media wasn't around until after the Beogram CD X, CD50 etc. was produced.Many decks will happily play CD-Rs but I wouldn't expect all to.
Thank you Martin for this. I really never thought that CD-Rs weren't around then. Even when you consider the advancement of the computer since then it is totally awesome. This has put this right in perspective for me.
Best regards
David
