Copy CDs
This post has 10 Replies | 1 Follower
Professor David A Flynn JP
Belfast, Northern Ireland
Posts 116
Professor David A Flynn JP Posted: Fri, May 9 2014 4:18 PM
Hello - as anyone experienced problems with a copy CD on either the 3300 CD player or the CDX2 player.  I made a copy of an old CD of mine to preserve for my use only and neither system would play it??
Is this a normal practice with B & O units that they don't play copies or is it just my two units don't like copy CDs made on my computer?
Many thanks
David[^o)
Professor David A Flynn JP LM
Big Smile
bidstonhall
Thailand 5560 miles from Struer
Posts 363
Hi there, I have a Beogram CD 4500 and it will play anything
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Fri, May 9 2014 6:03 PM
My CDX will play anything.
tournedos
Finland
Posts 7,357
It often helps if you don't burn the CDs at the maximum speed. Otherwise, CD-Rs should play with most any CD player, CD-RWs can be a different matter.
--mika
Millemissen
Flensborg, Denmark
Posts 14,680
The RW's don't play on a BG-CD4500.
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, May 9 2014 9:30 PM
Double-post... Yet again.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, May 9 2014 9:31 PM
All my old CD players - even the CDP-101 and the CD100 - will gladly play CDRs but not RWs obviously. However I was able to play one with my CD3300 by going directly to track 2.
Jacques
Posts 116
Thanks for this clearly I must have used RW when copying. Will try again. David Flynn
Big Smile
Posts 116
Thanks for this will try again. Must have been a CR-RW that I used will check and try again. David Flynn
Big Smile
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, May 10 2014 9:19 AM
We mustn't forget that the recordable CD media wasn't around until after the Beogram CD X, CD50 etc. was produced.
Many decks will happily play CD-Rs but I wouldn't expect all to.
Posts 116
Thank you Martin for this.  I really never thought that CD-Rs weren't around then.  Even when you consider the advancement of the computer since then it is totally awesome.  This has put this right in perspective for me.
Best regards
David
Big Smile
Page 1 of 1 (11 items) | RSS
