Turning Beolab 3500 on without the Beo4
Bruining
Posts 2
Bruining Posted: Sat, Jan 26 2013 9:41 AM
Like to connect my Beolab 3500 with my Apple. Learned that this can be done (via Airport) but in order to turn on the 3500 you still need a Beo4.
Does anyone know how to turn on the Beolab 3500 without using the Beo4 ?
Thanks !
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sat, Jan 26 2013 4:33 PM
You can turn on/off your BL3500 by touching the LED on the right side of the display.
Stefan
Bruining
Posts 2
Bruining replied on Sun, Jan 27 2013 12:22 PM
Thanks Stefan !
do you also know if you need the converter 1611 ton connect with the Apple airport ? Or will a cable with à 5 pin DIN be sufficiënt ?
stefan
Posts 2,920
stefan replied on Sun, Jan 27 2013 1:24 PM
I know from other members, that it works with a BL converter. I don`t know if it works when you just connect audio signals (L-R) to Masterlink.
First problem will be that ML uses balanced audio connection - but try and let us know....
Stefan
Page 1 of 1 (4 items) | RSS
