Like to connect my Beolab 3500 with my Apple. Learned that this can be done (via Airport) but in order to turn on the 3500 you still need a Beo4.
Does anyone know how to turn on the Beolab 3500 without using the Beo4 ?
Thanks !
You can turn on/off your BL3500 by touching the LED on the right side of the display.
Stefan
Thanks Stefan !
do you also know if you need the converter 1611 ton connect with the Apple airport ? Or will a cable with à 5 pin DIN be sufficiënt ?
I know from other members, that it works with a BL converter. I don`t know if it works when you just connect audio signals (L-R) to Masterlink.
First problem will be that ML uses balanced audio connection - but try and let us know....
