can any one advise the type of lube to use on the door gudies to see if this fix will work, doors work as should but there is a gap of 5 to 10 mm and when they open there is a dry sound as they need lube many thanks
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
You don't need to lubricate. The back cover and the PSU unit has to be opened in order to get acces to the 4 clamps/screws on top and bottom. The clamps are fixed on the doorstrings and they're only visible in the center when the doors are closed. Will make pictures if you're interested!
Brengen & Ophalen
that would be a great help if you could.....many thanks
Made a thread, good luck!
