beosound 3000 doors not shutting fully
This post has 3 Replies | 0 Followers
bramble
Posts 397
bramble Posted: Tue, Feb 5 2013 10:42 AM
can any one advise the type of lube to use on the door gudies to see if this fix  will work, doors work as should but there is a gap  of 5 to 10 mm and when they open there is a dry sound as they need  lube     many thanks
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 ๐Ÿ˜€๐Ÿ˜€
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Tue, Feb 5 2013 11:37 AM
You don't need to lubricate. The back cover and the PSU unit has to be opened in order to get acces to the 4 clamps/screws on top and bottom. The clamps are fixed on the doorstrings and they're only visible in the center when the doors are closed. Will make pictures if you're interested!
Brengen & Ophalen
bramble
Posts 397
bramble replied on Tue, Feb 5 2013 11:52 AM
that would be a great help if you could.....many thanks
Leslie
Posts 5,423
Silver Member
Leslie replied on Thu, Feb 7 2013 7:51 PM
Made a thread, good luck!
Brengen & Ophalen
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
