Serene signal problem
This post has 2 Replies | 2 Followers
Henry
Posts 2
Henry Posted: Sun, Feb 24 2013 10:21 AM
Dear all,
I have a question for any of you with a Serene or some good knowledge with this phone. Last week I clicked on Reset All Settings (within the Settings menu) and since then it seems the phone has lost all signal on the phone, on various SIM cards and operators.
The phone has never had such a problem before this, so I highly doubt there has been the coincidence of a technical failure at the very same time.
I would be very grateful to receive any advice or step by step checks. I have tried choosing the Vodafone operator manually without success.
Thanks in advance!
Henry
Posts 2
Henry replied on Mon, Feb 25 2013 12:14 PM
Would like to try asking once more if anyone could help me with this Settings problem I have?
And as an off topic for the mods, why have my past posts been deleted? I used to be a very active gold member of the BeoWorld forums. Thanks,
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Feb 25 2013 12:29 PM
Hi Henry,
unfortunately I can't help you with the Serene problem, but none of your posts have been deleted. If you haven't visited the forums for a while, you might not have noticed that about a year ago we had to archive all the old threads for technical reasons during a forum software upgrade. They are still available in read only format at http://archivedarchivedforum2.beoworld.org/forums/
For the same reason, you will need to update your personal settings (such as the avatar) on this new platform as well if you had altered them on the old forum.
--mika
Page 1 of 1 (3 items) | RSS
