Beolab 5 software
This post has 9 Replies | 1 Follower
Wilderwein
Posts 140
Wilderwein Posted: Sat, Jul 27 2013 4:08 PM
Hi all.
I wonder what the latest software is for the bl5 speakers.
Thanks in advance
Kareem
gysse2004
Hellerup
Posts 192
gysse2004 replied on Sat, Jul 27 2013 10:57 PM
I think there are 2 versions, dependent on if you have pincode or not: they are 1.61 without and 2.61 with pincode, if I remember right- why ? do you need to upgrade ?
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Wilderwein
Posts 140
Wilderwein replied on Sun, Jul 28 2013 12:59 AM
Hi there.
I have 3.1 today and wanted to know, what the latest one is. I have some problems with the spdif.
So is there any release after 3.2 ?
Regards
Kareem
soundproof
Posts 142
You're probably sending a non-native S/PDIF resolution to the BL5s. They can handle up to 24/96. Mine couldn't properly handle digital multi-channel.
Wilderwein
Posts 140
Wilderwein replied on Mon, Jul 29 2013 12:01 AM
Thank you for your answer. But I still want to know what the latest software is for the bl5 s.
Best regards
Kareem
Wilderwein
Posts 140
Wilderwein replied on Mon, Jul 29 2013 11:18 PM
The latest version is 3.30 but the one that solves the problem with spdif drop outs is 3.20.
So I will du the upgrade from 3.10 to 3.20 and see if it helps.
K
Wilderwein
Posts 140
Wilderwein replied on Mon, Jul 29 2013 11:19 PM
K
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Tue, Jul 30 2013 7:45 PM
Has to be done with the B&O servicetool.
Beobuddy
Posts 3,972
Listed per 07-2013.
Wilderwein
Posts 140
Yes unfortunately that is the case. I would love to be able to do it myself. But I dont think it is possible at the moment.
Page 1 of 1 (10 items) | RSS
