Hi all.
I wonder what the latest software is for the bl5 speakers.
Thanks in advance
Kareem
I think there are 2 versions, dependent on if you have pincode or not: they are 1.61 without and 2.61 with pincode, if I remember right- why ? do you need to upgrade ?
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Hi there.
I have 3.1 today and wanted to know, what the latest one is. I have some problems with the spdif.
So is there any release after 3.2 ?
Regards
You're probably sending a non-native S/PDIF resolution to the BL5s. They can handle up to 24/96. Mine couldn't properly handle digital multi-channel.
Thank you for your answer. But I still want to know what the latest software is for the bl5 s.
Best regards
The latest version is 3.30 but the one that solves the problem with spdif drop outs is 3.20.
So I will du the upgrade from 3.10 to 3.20 and see if it helps.
K
Has to be done with the B&O servicetool.
Listed per 07-2013.
Yes unfortunately that is the case. I would love to be able to do it myself. But I dont think it is possible at the moment.
