In the archived forum, I found a discussion and .xml file for the Oppo BDP-83. Would that file also work for the Oppo BDP-103 or is there a specific .xml file for the Oppo BDP-103?
Well, they both use 32bit NEC protocol, but I expect there will be a few commands that are different.
However, I have attached a ZIP file for the BDP-103 which was made from a translation of the data file used by the PUC.
Regards Keith....
Thank you, Keith!
