.xml file for Oppo BDP-103
beojeff
USA
Posts 2,012
beojeff Posted: Tue, Oct 8 2013 1:02 PM
In the archived forum, I found a discussion and .xml file for the Oppo BDP-83. Would that file also work for the Oppo BDP-103 or is there a specific .xml file for the Oppo BDP-103?
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Well, they both use 32bit NEC protocol, but I expect there will be a few commands that are different.
However, I have attached a ZIP file for the BDP-103 which was made from a translation of the data file used by the PUC.
Regards Keith....
beojeff
USA
Posts 2,012
beojeff replied on Tue, Oct 8 2013 8:38 PM
Thank you, Keith!
Page 1 of 1 (3 items) | RSS
