Setup BV 7-55 Beolab 10
This post has 2 Replies | 2 Followers
f5434964
Austria
Posts 206
f5434964 Posted: Mon, Apr 29 2013 9:31 PM
Hello!
Would I be able to do the setup of a BV 7-55? Getting each Part (panel, floor stand, labs) on its own to put it  together? I'm most concerned about any software setting/issue that could only be done by a specialist; connecting wires should not be the Problem...any special screw driver needed?
tv should be masterlinked with BS 3200 and BM5/BS5 with BL 3
As I'm Looking for a Beolab 10 - are there any Special brackets needed?
best regards
Elmar
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Mon, Apr 29 2013 11:07 PM
I have a 755 with a beolab 10 which sounds fab! You will need a beolab10 bracket from stb brackets which replaces the 7/6 bracket!
Hope this helps!
f5434964
Austria
Posts 206
f5434964 replied on Tue, Apr 30 2013 5:05 AM
Thanks a lot - that helps much; It looks marvellous!
I know the "basic setup" of a new BV must be done by a specialist; and I fear getting a second life telly I won't be able to get it to work...
Best regards
Elmar
Page 1 of 1 (3 items) | RSS
