Hello!
Would I be able to do the setup of a BV 7-55? Getting each Part (panel, floor stand, labs) on its own to put it together? I'm most concerned about any software setting/issue that could only be done by a specialist; connecting wires should not be the Problem...any special screw driver needed?
tv should be masterlinked with BS 3200 and BM5/BS5 with BL 3
As I'm Looking for a Beolab 10 - are there any Special brackets needed?
best regards
Elmar
Thanks a lot - that helps much; It looks marvellous!
I know the "basic setup" of a new BV must be done by a specialist; and I fear getting a second life telly I won't be able to get it to work...
Best regards
