beocord 5000 type 4715
This post has 8 Replies | 0 Followers
marc
s. wales uk
Posts 184
marc Posted: Tue, Apr 30 2013 9:42 PM
help needed
i came across a beocord 5000 type 4715, its cosmetic condition is near mint, everything seems to working except for the playing of tape, it rewinds and forwards tape counter works all the lights etc, however if i remove the tape and press play with tray empty it seems to work ok but when tape is loaded and play is pressed it goes into stop mode as if its to hard to turn tape.
marc
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Apr 30 2013 10:54 PM
I guess belt but be warned, this is the one bit of B&O that my old dealer refused to repair! He said that nothing good had ever happened when he tried to repair one! Big Smile Tim did repair mine but it still chews tapes!!
Peter
Playdrv4me
USA
Posts 477
Playdrv4me replied on Tue, Apr 30 2013 11:21 PM
In the lot of crappy condition stuff I got with my otherwise OK BM7000 and the RL6000 speakers was a BeoCord 7000 with broken mounts for the lid and a constant whirring noise whenever it was running which of course wouldn't play tapes either.
I just threw it in the trash. I know there's a lot of nostalgia around here but I can't imagine spending any time fixing a tape deck unless its part of an integrated unit like the BC9500, and that's before considering the BC5000 is considerably more complex than the 7. And even then it's really "just to know" its working.
Søren Hammer
Denmark
Posts 953
Playdrv4me:
Cassette can be a very decent format when using these decks; the 4715 is no slouch when in good working order, but I'd recommend to disable the back capstan to eliminate skew and ruined tapes - worn dual capstan transports are the worst handlers of tape.
I'm pretty happy with my Beocord 9000 and have had much joy with other decks in the 8000 series. They are good performers (20-20k Hz +/- 1½ dB at -20 dB), considering the narrow tracks and slow speed. Haven't been using cassette so much since I started using open reel tape instead; still using the 9000 occasionally as it blows 256 kb/s mp3's on my iPod out of the water.
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Cleviebaby
Exeter, United Kingdom
Posts 672
Marc,
I would echo Peter's comments. I have had two, one of which chewed up a favourite recording made 'off air' of a magical Keith Jarrett concert broadcast live by the BBC. I never trusted it again after that. In the end, it just became a very beautiful piece to sit alongside my BG 4004 and BM 4400.
Tim Jarman once showed me one he had adapted to make simpler and more reliable - unfortunately it didn't want to work even for him!
Cleve
marc
s. wales uk
Posts 184
marc replied on Wed, May 1 2013 7:47 AM
thank you all for your input on this, had it been in not so good condition i would be happy to let it go, its just in such a pristine cosmetic condition, picked it up for £20, does not look like many tapes have been passed through this machine and as i've said everything else works fine. Which brings me to ask is it worth getting a set of replacement belts or as one of you have said just use as show piece.
   marc
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Wed, May 1 2013 8:24 AM
marc:
Nothing ventured..... It will not diminish its pristine condition to have a go.
Peter
Earsdon
Posts 11,991
Peter replied on Wed, May 1 2013 3:20 PM
I agree - but don't use it with tapes you cannot replace! It will behave all nicely and then laugh at you as it strips the magnetic covering off your favourite tape! Big Smile
Peter
marc
s. wales uk
Posts 184
marc replied on Wed, May 1 2013 11:35 PM
ok , i will get hold of belt kit and what happens, by the way peter did you see my post on beomster 8000, was woudering if you know the best person for the job on repair, at the moment i've taken it to hinchleys in cardiff they were a b&o dealer for many years but now just deal with other brands, just need back up plan if they fail.
marc
Page 1 of 1 (9 items) | RSS
