Hello again and question about Beolab 5000 speaker placement
This post has 13 Replies | 2 Followers
benkap
Oslo, Norway
Posts 41
benkap Posted: Thu, Feb 21 2013 2:08 PM
Hello all!
It's been a loooong time since I was here last time. What can I say but life is busy and offers unexpected turns sometimes. I just reupgraded myself to gold standard and even got my "f" back Cool
After living in a smaller flat for a couple of years - to my regret not with enough wall space for large wall mounted spakers - we'll soon move in to a big apartment with several options for placing large wall mounted speakers. Double the joy! I currently have a set of CX100's cheering me up and they definitely do more than ok but they're no BL5000's Wink
My question is if it matters for the sound quality what type of wall a set of BL5000's are mounted on. Dry wall vs. brick et cetera. Most walls in the new place are brick but one of the options for speaker placement is on dry wall. I don't want the sound to be all boomy and bounce through to the wrong places so any suggestions are greatly appreciated.
Cheers,
Ben
DMacri
United States
Posts 881
DMacri replied on Thu, Feb 21 2013 2:28 PM
I think you'd have much better sound isolation from mounting to the brick walls. The drywall will transfer sound to the room behind it more easily. The only important thing with the wall mount speakers is the proximity of the wall itself. It acts as a baffle and bass reinforcement. They are designed for that placement option. Most other speakers would sound too boomy mounted to the wall, unless they really lack bass on their own like CX series speakers - they can be wall mounted.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
benkap
Oslo, Norway
Posts 41
benkap replied on Fri, Feb 22 2013 7:34 AM
Thanks very much for your reply, DMacri! I'll try to avoid the drywall placement and go for brick, really looking forward to having my babies back up Big Smile
I actually had a pair of CX100's wall mounted some years ago for a short while but I thought it looked wrong and took them down.
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Until very recently I had 3 pairs of Beolab 5000's all mounted on drywall and they sound fantastic!
The only reason for selling 2 pairs is that I'm downsizing my property and wont have room for them in the future.
My walls all have fibreglass insulation in the voids and there was no problem with sound transfer, room to room.
Regards Graham
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Fri, Feb 22 2013 7:46 AM
joeyboygolf:
Are they sold ?
benkap
Oslo, Norway
Posts 41
benkap replied on Fri, Feb 22 2013 9:27 AM
joeyboygolf:
No booming at all either? And did the wall carry the weight ok?
3 pairs! I think I'd have a hard time getting the go signal for that many Wink
j0hnbarker
Posts 187
Like Graham I have my (slightly lighter) BV 5000s mounted on dry-lined walls with fibreglass insulation. There is no boom and the sound quality is excellent.
In terms of mounting options, I initially used special plasterboard anchors for the standard BV 5000 mounting frame. When I moved the speakers I simply used some rawl plugs and they do the job admirably and make less of a mess of the wall to boot!
joeyboygolf
Posts 4,188
valve1:
joeyboygolf:
Are they sold ?
Sold with little advertising. On one occasion,clients came round to collect a 6500 system and were so impressed that they went away with a pair  of Lab 5000's the other pair sold by word of mouth.
Regards Graham
joeyboygolf
Posts 4,188
benkap:
joeyboygolf:
No booming whatsoever.
Regards Graham
benkap
Oslo, Norway
Posts 41
benkap replied on Mon, Feb 25 2013 7:32 AM
Thanks very much for your input, j0hnbarker and Graham. Much appreciated!
Come May we'll see what wall they end up on. I'll make sure to post a picture Smile
benkap
Oslo, Norway
Posts 41
benkap
Oslo, Norway
Posts 41
benkap replied on Wed, Jun 19 2013 8:43 AM
Finally got my system up. The BL5000's are mounted on brick wall and are just so enjoyable to listen to. Great to have them back up!
They're fed from a BM6500 with BG6500 CD and BG4500 record player. WIll try and get some pictures up shortly. Is there a forum thread somewhere for this or would it be OK if I make my own?
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Jun 19 2013 8:54 AM
Flash your B&O - new thread!
Ralf
benkap
Oslo, Norway
Posts 41
benkap replied on Wed, Jun 19 2013 10:30 AM
kallasr:
Ah, thanks very much for the pointer, Ralf Smile
Page 1 of 1 (14 items) | RSS
