Beovox 2700
Orava
Finland
Posts 991
Orava Posted: Wed, Apr 11 2012 8:57 AM
Before tearing apart. Is fret on these with glue, stickers or needles?
There is something rattling inside.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Apr 11 2012 9:04 AM
The front baffle is 3mm hard cardboard with cloth.
It's glued to the aluminum trim.
Use a 3-4cm wide spatula and work around the edge a couple of times, lifting the board
away from the trim little by little and it will losen nicely.
Don't force anything or the baffle will break.
You will find the woofers in need of refoaming, the surrounds will be falling apart, if that's the
rattling you hear, I can't say.
Orava
Finland
Posts 991
Orava replied on Wed, Apr 11 2012 12:49 PM
Dillen:
Refoaming! My favorite.Surprise  Oh, well... Thanks for instructions.
BTW, I h a v e to do something to order those belts from you finally, soon.
Page 1 of 1 (3 items) | RSS
