Before tearing apart. Is fret on these with glue, stickers or needles?
There is something rattling inside.
The front baffle is 3mm hard cardboard with cloth.It's glued to the aluminum trim.Use a 3-4cm wide spatula and work around the edge a couple of times, lifting the boardaway from the trim little by little and it will losen nicely.Don't force anything or the baffle will break.
You will find the woofers in need of refoaming, the surrounds will be falling apart, if that's therattling you hear, I can't say.
Dillen: You will find the woofers in need of refoaming, the surrounds will be falling apart, if that's therattling you hear, I can't say. Martin
Refoaming! My favorite. Oh, well... Thanks for instructions.
BTW, I h a v e to do something to order those belts from you finally, soon.
