Hi gents,
My beloved Beo5 have been to the floor and the front glass have come loose. Its not cracked or anything so I am wondering if here is any hope of rescuing it? (Without replacing the whole display unit)
rgds
Thomas
Format 0 😀😎
Thomas,
With the glass off, is there any other damage to the screen components and/or the inside (rear) of the glass where it is fitted to the back section ?
Regards Keith....
Hi Keith,
no, no other damage as far as I can see.
Br
thomas
If you hold the glass back in place does the display still work ?
Hi again and thanks for taking the time to answer.
Not all buttons work and the ones that work needs a bit harder pressing than normally.
br
That is exactly what I was concerned about. The construction is such that just fixing the glass back more than often will not work.
I am afraid you will need to get it repaired at a B&O Dealer, but there is good and bad news about that. I will start with the good news and that is because the Beo5 screens are no longer available, a Beo6 screen unit will be fitted and it will become a true Beo6. Now the bad news, clearly your Beo5 is out of warranty, so you will have to pay the repair cost which will be quite high.
Hi again,
I was afraid of that. Well its with my local dealer now, so i'll see what its going to cost me.
Thanks for your time and effort!
how much for this repair?
