Dear Forum,
can I connect a Beolink Active (Type 1636, SW 1.1) to a Beomaster 7000 using a Beolink Converter (Type 1611, SW 1.3)?
I have not yet been able to get this setup to work.
I know all components are working!
Ralf
Thanks for the fast reply!
I will do exactly as you described and give feedback.
I worked out fine!
The error was probably the wrong option settings.
So after selling the Beosound 9000 MKII, my Beolab 4000 are playing via the Beomaster.
Using the Beomaster every day know!
Kids can put in a CD in the Beogram CD (in my home Office) and listen to it in the living room.
Since we also got a SONOS connected to the Beomaster 7000 via enjoy Spotify in the living as we used when we had the Beosound 9000 (only missing its iconic design...).
Oh, and the Masterlink is based on CAT/Network cabling (used two ML to RJ45 cables).Thanks for your helpt!
