Create PUC for Beosystem4 based TV
This post has 27 Replies | 3 Followers
lano
Posts 161
lano Posted: Sat, Jun 13 2015 10:19 AM
Is it possible to create a PUC for a Beosystem 4 based TV if it is not already available? If so, can you do it your self based on a template? Anyone that knows how to do it?
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Jun 13 2015 10:41 AM
As far as I know it's not possible to do it by yourself, but B&O can create a special PUC. But I guess for a lot of money.
Regards
Räuber
BeoMotion
Posts 384
BeoMotion replied on Sat, Jun 13 2015 12:23 PM
It is possible if you know what you are doing.
You need to have a good understanding of how IR protocols works in general and of the PUC file syntax.
Custom PUC files can then be uploaded to the TV using an USB stick.
lano
Posts 161
lano replied on Sat, Jun 13 2015 3:44 PM
Anyone that have a sample PUC code?
Radiomekaniker
Posts 49
What box do you need a puc file for, or what do you like to modify on a specific puc file?
Fl_ip
Posts 160
Fl_ip replied on Sat, Jun 13 2015 7:44 PM
For the dealer it is now possible to change the PUC file. There has been software released to change the settings and commands.
lano
Posts 161
lano replied on Sat, Jun 13 2015 9:26 PM
Radiomekaniker:
I need a PUC file for a Beovision 4. Actually just to turn it on and off with Beosystem 4
BeoMotion
Posts 384
BeoMotion replied on Sat, Jun 13 2015 9:35 PM
lano:
The BV4 panels are controlled via RS232 connection. Only the very latest BV4 are supported by BS4. I don't think that a PUC will help you that much.
lano
Posts 161
lano replied on Sat, Jun 13 2015 9:38 PM
BeoMotion:
Why shouldn't a PUC help? All I need it to is to turn the monitor on and off. It works with a Panasonic remote so why shouldn't it work via PUC?
BeoMotion
Posts 384
BeoMotion replied on Sat, Jun 13 2015 9:45 PM
lano:
Ok. I wasn't aware of that this trick is possible with all BV4 screens.
I think there is already a Panasonic screen PUC in the database.
If you can't find it with the search function within your BS4 maybe ask your dealer.
lano
Posts 161
lano replied on Sun, Jun 14 2015 9:33 AM
BeoMotion:
Ok. I wasn't aware of that this trick is possible with all BV4 screens. I think there is already a Panasonic screen PUC in the database. If you can't find it with the search function within your BS4 maybe ask your dealer.
There is a hole in the frame in the lower left corner where you can point the remote and control the panel. Should be possible to attach a PUC there also. However I can't find any Panasonic display PUC in the online DB.
lano
Posts 161
lano replied on Sat, Jul 4 2015 3:28 PM
Do you have any more information on how to do this?
lano
Posts 161
lano replied on Tue, Jul 7 2015 8:18 AM
BeoMotion:
Do you have an example of a PUC file that I can have a look at?
ari
Posts 144
ari replied on Wed, Jul 8 2015 10:30 AM
+1 would be a great help
Clark
Posts 1
Hi
Here you find a version of the panasonic screen dec file.
Download and remove .txt
Cheers
Clark
lano
Posts 161
lano replied on Fri, Jul 10 2015 5:29 PM
Thaks for the file!
I guess I must be doing something wrong because the BS4 tells me "no puc tabels found" when I try to upload it?
What I have done:
  • Downloaded the file
  • Removed .txt
  • Copy the file to a USB
  • Inserted the USB in the BS4
  • Tried to select a PUC from the USB via setting/screen
Do I need to do something special with the file/USB for the BS4 to recognize it?
lano
Posts 161
lano replied on Sat, Jul 18 2015 9:43 AM
Is there someone on the forum that have had a PUC table loaded to a Beosystem4 based TV via USB?
BeoMegaMan
Posts 601
Put the file in a folder then plug it in.
Ah, you know... A little B&O here, a little there
ari
Posts 144
ari replied on Sat, Jul 18 2015 5:59 PM
T
Clark:
Hi
Cheers
Clark
Thanks for this. Does anyone have any advice on how to use this file to create my own custom PUC file for my own device not on the B&O PUC list?
lano
Posts 161
lano replied on Sat, Jul 18 2015 11:05 PM
Doesn't work for me. Do I need to name the folder something special? Do the USB needs to be in any special format?
Do you have an other example file that I could try or could you check the file for the BV4 to see if it works?
lue0203
Posts 5
lue0203 replied on Sun, Aug 14 2016 3:25 PM
Can this file be used in System 4?
the file name maybe *.decx ?
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sun, Aug 14 2016 7:42 PM
lue0203:
All of the more recent products use the .decx file format which is different to the older .dec format used with the masterlink era BeoVisions and BeoSystem 3 for example, so this file will not work with the BeoSystem 4.
Martin,
lue0203
Posts 5
lue0203 replied on Mon, Aug 15 2016 4:25 AM
Thanks.
Anyone have new PUC for Panasonic Tv's ?
TWG
Posts 1,672
TWG replied on Mon, Aug 15 2016 6:41 AM
Is there any documentation regarding the older format for Beosystem 3 PUC?
Can I upload it via an USB stick into a Beosystem 3, too?
Very interesting topic!
lue0203
Posts 5
lue0203 replied on Thu, Aug 18 2016 2:55 PM
Anybody can provide system4's PUC for Panasonic TV ?
I can't get it in my country.
lano
Posts 161
The attached file works for the Beovision 4 Plasma screens (which is Panasonic panels). Rename the file from .txt to .decx
I do not know if they work for Panasonic TV also, but you could always try.
lue0203
Posts 5
lue0203 replied on Fri, Aug 19 2016 3:05 AM
Thank you very much.
I will try it.
lue0203
Posts 5
lue0203 replied on Fri, Aug 19 2016 9:27 AM
Thank  lano .
This file can be read by system 4, but can't use to control TV .Sad
Anybody have Panasonic TV PUC for system 4 ?
Page 1 of 1 (28 items) | RSS
