It is possible if you know what you are doing.
You need to have a good understanding of how IR protocols works in general and of the PUC file syntax.
Custom PUC files can then be uploaded to the TV using an USB stick.
Radiomekaniker:What box do you need a puc file for, or what do you like to modify on a specific puc file?
lano:I need a PUC file for a Beovision 4. Actually just to turn it on and off with Beosystem 4
The BV4 panels are controlled via RS232 connection. Only the very latest BV4 are supported by BS4. I don't think that a PUC will help you that much.
BeoMotion:The BV4 panels are controlled via RS232 connection. Only the very latest BV4 are supported by BS4. I don't think that a PUC will help you that much.
lano:Why shouldn't a PUC help? All I need it to is to turn the monitor on and off. It works with a Panasonic remote so why shouldn't it work via PUC?
Ok. I wasn't aware of that this trick is possible with all BV4 screens. I think there is already a Panasonic screen PUC in the database. If you can't find it with the search function within your BS4 maybe ask your dealer.
BeoMotion:Ok. I wasn't aware of that this trick is possible with all BV4 screens. I think there is already a Panasonic screen PUC in the database. If you can't find it with the search function within your BS4 maybe ask your dealer.
Do you have any more information on how to do this?
BeoMotion:It is possible if you know what you are doing. You need to have a good understanding of how IR protocols works in general and of the PUC file syntax. Custom PUC files can then be uploaded to the TV using an USB stick.
+1 would be a great help
Hi
Here you find a version of the panasonic screen dec file.
Download and remove .txt
Cheers
Clark
Thaks for the file!
I guess I must be doing something wrong because the BS4 tells me "no puc tabels found" when I try to upload it?
What I have done:
Do I need to do something special with the file/USB for the BS4 to recognize it?
Ah, you know... A little B&O here, a little there
T
Clark: Hi Here you find a version of the panasonic screen dec file. Download and remove .txt Cheers Clark
Thanks for this. Does anyone have any advice on how to use this file to create my own custom PUC file for my own device not on the B&O PUC list?
Can this file be used in System 4?
the file name maybe *.decx ?
lue0203: Can this file be used in System 4? the file name maybe *.decx ?
All of the more recent products use the .decx file format which is different to the older .dec format used with the masterlink era BeoVisions and BeoSystem 3 for example, so this file will not work with the BeoSystem 4.
Martin,
Thanks.
Anyone have new PUC for Panasonic Tv's ?
Is there any documentation regarding the older format for Beosystem 3 PUC? Can I upload it via an USB stick into a Beosystem 3, too?Very interesting topic!
Anybody can provide system4's PUC for Panasonic TV ?
I can't get it in my country.
The attached file works for the Beovision 4 Plasma screens (which is Panasonic panels). Rename the file from .txt to .decx
I do not know if they work for Panasonic TV also, but you could always try.
Thank you very much.
I will try it.
Thank lano .
This file can be read by system 4, but can't use to control TV .
Anybody have Panasonic TV PUC for system 4 ?
