Your model is not in the PUC library. The nearest Toshiba player in the PUC library is Toshiba BDX3100KE which may use compatible IR codes.
Regards Keith....
I've had the same with virgin supplying a TiVo that's "not on the list" and has a curved lens over the ir window anyway !
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
