Apple TV (2012 model) with BeoVision 7-32 MK IV
This post has 7 Replies | 2 Followers
mhoutman
The Netherlands
Posts 2
mhoutman Posted: Sun, Mar 18 2012 6:12 PM
As the Apple TV 2012 is brand new and I finally want to buy one, I wonder if I need any other parts (except the standard Apple HDMI cable) to connect the Apple TV to my BeoVision 7-32 MK IV.
parts:
http://store.apple.com/nl/browse/home/shop_ipod/family/apple_tv
http://store.apple.com/nl/product/MC838ZM/A
Your advice is very much appreciated Smile
hotknife
Germany
Posts 840
hotknife replied on Sun, Mar 18 2012 6:57 PM
I do not think so, because it is roughly the same as the 2011 model. You only need the PUC to control the ATV with your Beo.
LOEWE bild 5.55 OLED + AppleTV; BS4; BL9; BL8000 MKII all black
Vienna
make an educated guess
Posts 1,090
Vienna replied on Sun, Mar 18 2012 7:23 PM
mhoutman:
... I wonder if I need any other parts (except the standard Apple HDMI cable)
hotknife:
If it is really a BeoVision 7-32 MK IV, matters will become quite complicated!
The BeoVision 7-32 MK IV has a DVI-I input and no optical sound input.
For the picture you'll need a HDMI <> DVI-D cable
For the sound you'll need
an optical to electrical digital converter/translator
an optical Toslink cable from ATV to digital translator box
a  RCA/Cinch digital cable from digital translator box to connect to B&O digital in
It is very likely you'll also need to have the AC3 chip exchanged to the recent version ...
And you'll need an IR-transmitter cable if you want to control the unit via Beo 4/5/6 remote
For more details have a look at this thread: http://archivedforum2.beoworld.org/forums/t/330.aspx
mhoutman
The Netherlands
Posts 2
mhoutman replied on Sun, Mar 18 2012 7:35 PM
Sorry this sound stupid, but I thought my TV is also suited for HDMI cables. BTW I have the BeoLab 7-1 speakers.
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Sun, Mar 18 2012 8:09 PM
I have a MK3  7-32 Which has DVI but the MK4 & 5 Should have HDMI as it all changed after the MK3?
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Sun, Mar 18 2012 8:10 PM
Vienna
Posts 1,090
Vienna replied on Mon, Mar 19 2012 2:18 AM
mhoutman:
Bv7Mk3:
Sorry folks - the unpleasant truth is:
7-40 Mk3 - introduced fall 2007 - was the first version of the BVi 7 series with 4 HDMI (based on the BeoSystem 3 engine)
7-32 MK4 - introduced fall 2008 - was still equipped with just ONE DVI-I but had HDCP support "on board"
and finally, the 7-32 got in the latest Mk 5 version  - introduced spring 2009 - 2 HDMI inputs ...
beojeff
USA
Posts 2,012
beojeff replied on Mon, Mar 19 2012 10:46 AM
When considering using an HDMI switcher, you should be aware that many people encountered problems with the HDCP handshake when using the new 1080p Apple TV with an HDMI switcher. I use the B&O-recommended Gefen switcher and have had no problems at all. I think it's especially important with the new Apple TV to use a high quality HDMI cable or you may have handshake issues.
Page 1 of 1 (8 items) | RSS
