XML for Optoma screen
This post has 1 Reply | 0 Followers
beojeff
USA
Posts 2,012
beojeff Posted: Fri, Oct 18 2013 10:32 AM
Is there an XML for the Optoma Panoview GrayWolf II projector screen?
The IR codes are in the Harmony remote database and can control it perfectly with my Harmony remote. Still, I would like to be able to control it from my Beo6 as well.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
If you can provide the IR codes in Pronto HEX format I should be able to make an XML file
Regards Keith....
Page 1 of 1 (2 items) | RSS
