Is there an XML for the Optoma Panoview GrayWolf II projector screen?
The IR codes are in the Harmony remote database and can control it perfectly with my Harmony remote. Still, I would like to be able to control it from my Beo6 as well.
If you can provide the IR codes in Pronto HEX format I should be able to make an XML file
Regards Keith....
