It is time to retire our Beovision 1 and we are trying to work out how to remove it from, and along with, the motorized wall bracket. Any helpful advice would be great. Thanks.
A Very Warm Welcome to Beoworld..
As you are aware the BeoVision 1 is very heavy and so this is certainly a two man job.
Once all cables are removed, the TV must be lifted about 6-7 inches straight up to remove.
Regards Keith....
Keith Saunders:A Very Warm Welcome to Beoworld.. As you are aware the BeoVision 1 is very heavy and so this is certainly a two man job. Once all cables are removed, the TV must be lifted about 6-7 inches straight up to remove. Regards Keith....
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Thanks Keith. Will be trying to get the TV off the wall this pm - and you are right - it is very heavy. Awesome TV but we need to move into the millennium.
Successfully and safely removed. Thanks for your help. Catherine
