Help - how to remove Beovision 1 with wall bracket
catclark
Posts 3
catclark Posted: Fri, Apr 14 2017 9:24 AM
It is time to retire our Beovision 1 and we are trying to work out how to remove it from, and along with,  the motorized wall bracket.  Any helpful advice would be great.  Thanks.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
A Very Warm Welcome to Beoworld..
As you are aware the BeoVision 1 is very heavy and so this is certainly a two man job.
Once all cables are removed, the TV must be lifted about 6-7 inches straight up to remove.
Regards Keith....
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Apr 14 2017 2:41 PM
Keith Saunders:
Regards Keith....
You also need to unscrew the small screw your can see on the right picture.
catclark
Posts 3
catclark replied on Fri, Apr 14 2017 3:11 PM
Thanks Keith.  Will be trying to get the TV off the wall this pm - and you are right - it is very heavy.  Awesome TV but we need to move into the millennium.
catclark
Posts 3
catclark replied on Sat, Apr 15 2017 9:21 PM
Successfully and safely removed.   Thanks for your help. Catherine
Page 1 of 1 (5 items) | RSS
