Problem with A9
maillotpa
Posts 19
maillotpa Posted: Sat, Oct 26 2013 6:44 PM
Hi everybody  my A9  disconnect  when  listen music  in my iPad  a person what a idea  thanks
Michael
Sweden
Posts 2,578
Michael replied on Thu, Nov 7 2013 4:15 AM
Probably not a good connection to your router. If your iPad and/or A9 is far from the router and/or if your router is weak/slow/old this is what will happen. I would suggest moving your units closer together if possible and also check that you have a "good enough" router. I strongly suggest you use a 802.11n router that has mimo-antennas. Good Luck!
Page 1 of 1 (2 items) | RSS
