Hi everybody my A9 disconnect when listen music in my iPad a person what a idea thanks
Probably not a good connection to your router. If your iPad and/or A9 is far from the router and/or if your router is weak/slow/old this is what will happen. I would suggest moving your units closer together if possible and also check that you have a "good enough" router. I strongly suggest you use a 802.11n router that has mimo-antennas. Good Luck!
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
