I currently have BL1s attached to a BV11-55 and use all the speakers for movies as well as listening to music via appletv or through my BS9000 that is also connected to the BV11. I am thinking of getting a subwoofer (bl 19 perhaps) but wondering if anyone had feedback on whether adding a sub to the BV11-55 made much of a difference for music or bray.
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
Hi, there have been a few discussions recently over the value of adding a BL11 or BL19 to your BV. Have a look through the forums.
In your specific case, it's a little more tricky as the BL1s are a very powerful set of speakers (with decent bass), so a sub will make less of a difference, I think. Few people have given much feedback on the BL19, so far, so it might be wiser to ask your dealer if you can borrow a unit for a couple of days, see if it enhances your setup?
I had a pair of BL9s connected to my old BV7 and I didn't feel the need a sub in this setup, as the BL9 could handle the bass. I did have a BL2 at one point, but sold it, as the only thing it appeared to do was rock the floor of the room, whenever there was an explosion in a movie.
Thank you both for the feedback. As suggested I will also try to borrow a BL19 and see the impact. I watched Prometheus last night, and at level 60 volume it was fantastic. But alas I cannot stay at this level for either movies or music as I am sure my neighbours would not enjoy it. Hoping the real impact would be with music....agree the bass on the BL1s have always been surprisingly weak.
Stan:I have bl1s, and I do believe that they benefit from a sub
As do I. I use the bl2 and have no problems with it. With the Avant and movies it is very boomy but is that not the way the movies are recorded ?
Hope to try the new sub later to day.
