Hello
Today I use all my music digitally via airplay on my Bang & Olufsen products.
But i have a lot of records I would like use again - is it possible in any way to connect a Beogram to a Beovision 11.
If so what models?
Thanks in advance
It's a possibility which I am looking into.
You would need a turntable with built in RIAA or a stand alone preamp if not present in the turntable.
More later.
Regards Graham
Hi Graham
If it is possible would the cable be 8 pin din (beogram) to 9 pin mini din (BV11)
Is it even possible to get that kind of cabler or would I need an adapter.
blx: Hi Graham If it is possible would the cable be 8 pin din (beogram) to 9 pin mini din (BV11) Is it even possible to get that kind of cabler or would I need an adapter. Thanks
I am told that B&O have a cable available for the job. it would be 7pin DIN socket to mini din plug suitable for the AV socket on the Beovision 11.
I am have a problem in finding the part number from my dealer.
