Connect Beogram Record Deck to Beovision 11
blx
Posts 2
blx Posted: Mon, Dec 23 2013 9:42 AM
Hello
Today I use all my music digitally via airplay on my Bang & Olufsen products.
But i have a lot of records I would like use again - is it possible in any way to connect a Beogram to a Beovision 11.
If so what models?
Thanks in advance
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
It's a possibility which I am looking into.
You would need a turntable with built in RIAA or a stand alone preamp if not present in the turntable.
More later.
Regards Graham
blx
Posts 2
blx replied on Sat, Dec 28 2013 4:33 PM
Hi Graham
If it is possible would the cable be 8 pin din (beogram) to 9 pin mini din (BV11)
Is it even possible to get that kind of cabler or would I need an adapter.
joeyboygolf
Posts 4,188
blx:
Hi Graham
I am told that B&O have a cable available for the job. it would be 7pin DIN socket to mini din plug suitable for the AV socket on the Beovision 11.
I am have a problem in finding the part number from my dealer.
Regards Graham
Page 1 of 1 (4 items) | RSS
