Hi guys,
I connected my Sonos Connect through the SPDIF on my BV11 - hooked up the A.Mem button on the Beo4 and the sound worked instantly - but!
The BV handles/processes the sound causing a lag/delay to the other Sonos-zones in my house.
On my old Onkyo 808 I could choose "Direct" as a listening mode, causing the amp to play the sound from the sonos without processing/delaying it.
Do you have any suggestions for me to try on the BV to achieve the same?
I already tried P.Mute to disable the video (and video processor) but the delay is not caused by that.
I also tried to set the listening mode to custom and disable the True Image (Setting it to 1:1) instead.
The delay happens both when using the built in speakers and when using BL9 connected to the BV11.
So your speakers are connected to both your V1 and the Powerlink Switch?
Unfortunately this doesn't help either...
Nothing - sound is still delayed just as I mentioned in my initial post :)
Ok, so I bought the bossscom now.
But now my Beolab 9's have a nasty background noise.
I got a rj45 to powerlink on in 2, the rca from my sonos on in 1
One powerlink to the right speaker from the bossscom out, and another powerlink from the right speaker to the left speaker.
Any ideas on what is causing the noise? Noise is different on in 1 & 2...
BR
