Beovision 11 Sonos delay
This post has 8 Replies | 2 Followers
henkedk
Posts 5
henkedk Posted: Fri, Nov 29 2013 5:57 PM
Hi guys,
I connected my Sonos Connect through the SPDIF on my BV11 - hooked up the A.Mem button on the Beo4 and the sound worked instantly - but!
The BV handles/processes the sound causing a lag/delay to the other Sonos-zones in my house.
On my old Onkyo 808 I could choose "Direct" as a listening mode, causing the amp to play the sound from the sonos without processing/delaying it.
Do you have any suggestions for me to try on the BV to achieve the same?
I already tried P.Mute to disable the video (and video processor) but the delay is not caused by that.
I also tried to set the listening mode to custom and disable the True Image (Setting it to 1:1) instead.
The delay happens both when using the built in speakers and when using BL9 connected to the BV11.
jans
Belgium
Posts 394
jans replied on Fri, Nov 29 2013 6:16 PM
I have a V1 in a similar setup (V1 - BL8000 - Sonos)
A delay with when routing Sonos thru the V1 inevitably results in a delay no matter which option or setting you choose.
I finally bought a Bosscom Powerlink Switch. This works fine.
henkedk
Posts 5
henkedk replied on Fri, Nov 29 2013 6:20 PM
So your speakers are connected to both your V1 and the Powerlink Switch?
jans
Belgium
Posts 394
jans replied on Fri, Nov 29 2013 6:40 PM
Both the V1 and the Sonos are connected to the Powerlink Switch. The speakers in turn are also connected to the Powerlink switch.
You can find more info on the website of vendors such as Bosscom or Almando.
MartinW
Posts 389
MartinW replied on Fri, Nov 29 2013 10:48 PM
Did you try Game Mode on the V1? It bypasses part of the picture processing to minimise lag when you're trying not to get shot in Call of Duty - it might help with the sound delay?
StUrrock
Posts 995
StUrrock replied on Sat, Nov 30 2013 8:11 AM
What happens if you mute the picture?
henkedk
Posts 5
henkedk replied on Sat, Nov 30 2013 1:11 PM
Unfortunately this doesn't help either...
henkedk
Posts 5
henkedk replied on Sat, Nov 30 2013 1:12 PM
Nothing - sound is still delayed just as I mentioned in my initial post :)
henkedk
Posts 5
henkedk replied on Mon, Dec 16 2013 5:53 PM
Ok, so I bought the bossscom now.
But now my Beolab 9's have a nasty background noise.
I got a rj45 to powerlink on in 2, the rca from my sonos on in 1
One powerlink to the right speaker from the bossscom out, and another powerlink from the right speaker to the left speaker.
Any ideas on what is causing the noise? Noise is different on in 1 & 2...
BR
Page 1 of 1 (9 items) | RSS
