beosound 5 stays on when changing source on beovision
olvisab
Posts 1,391
olvisab Posted: Wed, Dec 25 2013 7:28 PM
Hi and merry christmas to everybody
If I change the source on the TV (DTV or v.mem) after playing radio or cd, the BS5/BM5 is still on showing the last radios or cd played.
Option 0 for the BS5
Option 2 for the tv
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Dec 26 2013 9:03 AM
Hi olvisab,
I assume the reason for this behaviour is not the BS5/BM5, but the BV7, because BS5/BM5 gets the command to shut down from BV7.
I have a similar problem with my BV10 in link room (option 6). I had reported this to my dealer and Beocare in 2011, but nobody is able to solve the problem by providing a software update. Very bad service from B&O!
Merry christmas!
Räuber
olvisab
Posts 1,391
olvisab replied on Thu, Dec 26 2013 9:14 AM
Hi Raueber,
The problem is that my bv 7 40 has been fully updated 10 days ago. So I don't think it is due to this.
I add a MLGW. I will check if it doesn't modify my set up.
I will let you know if I find a way to solve this.
I think I didn't have this behaviour before... updating my BV.
BR
OLivier
stefan
200 miles from Struer
Posts 2,920
stefan replied on Thu, Dec 26 2013 3:19 PM
Are you using a Beo4 with navigation button?
If so, To what ZONE is it set to?
Not sure, but try VIDEO with your setup...
merry christmas...
Stefan
olvisab
Posts 1,391
olvisab replied on Thu, Dec 26 2013 3:21 PM
Hi Stefan,
I don't use a beo4 with navigation button
stefan
Posts 2,920
stefan replied on Thu, Dec 26 2013 5:03 PM
Ok - I thought you have the same fault I had.
Now I'd disconnect the BV from mains for 10 minutes and reconnect.
Set options again and try again. BS5 is audiomaster?
Does your setup behave the same way vice versa?
Does your BV stay on (screen) when you change from video to audio?
Stefan
Page 1 of 1 (6 items) | RSS
