Hi and merry christmas to everybody
If I change the source on the TV (DTV or v.mem) after playing radio or cd, the BS5/BM5 is still on showing the last radios or cd played.
Option 0 for the BS5
Option 2 for the tv
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Hi Raueber,
The problem is that my bv 7 40 has been fully updated 10 days ago. So I don't think it is due to this.
I add a MLGW. I will check if it doesn't modify my set up.
I will let you know if I find a way to solve this.
I think I didn't have this behaviour before... updating my BV.
BR
OLivier
Are you using a Beo4 with navigation button?
If so, To what ZONE is it set to?
Not sure, but try VIDEO with your setup...
merry christmas...
Stefan
Hi Stefan,
I don't use a beo4 with navigation button
Ok - I thought you have the same fault I had.
Now I'd disconnect the BV from mains for 10 minutes and reconnect.
Set options again and try again. BS5 is audiomaster?
Does your setup behave the same way vice versa?
Does your BV stay on (screen) when you change from video to audio?
