Beovision MX4002
This post has 1 Reply | 0 Followers
andymoutr
Posts 1
andymoutr Posted: Tue, Dec 24 2013 12:17 PM
Problem with power 'on'. the green light does not stay 'on'. It's like the charge is not held and the picture isn't there. Can I fix this problem with a spare? my best answer is the transformer?.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Wed, Dec 25 2013 4:37 PM
If you have a standby led, which will not turn into green, then there are powersupply problems.
Standard issues, mostly not the transformer, but parts around the transformer. Not a job for the amateur because of the high voltage risk.
Page 1 of 1 (2 items) | RSS
