Problem with power 'on'. the green light does not stay 'on'. It's like the charge is not held and the picture isn't there. Can I fix this problem with a spare? my best answer is the transformer?.
If you have a standby led, which will not turn into green, then there are powersupply problems.
Standard issues, mostly not the transformer, but parts around the transformer. Not a job for the amateur because of the high voltage risk.
