Beosound 9000 backup battery
This post has 9 Replies | 0 Followers
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Sun, Aug 2 2020 7:15 PM
Hi all.
Anyone know where to get a BS9000 backup battery ? Or at least know the specs. I have a BS9000 with a leaking(white supstance) battery, it measures 3.18v, but I think it should be changed before making anymore damage.
It is a 3 legged upright button cell with orange edge, and I can find some that looks like it, but with yellow edge, and all seems to be some sort of china version, which I find weird ?
In the service manual, B1 is marked as "specially adapted version".
/Weebyx
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
I know it is a 3 volt battery. Does your battery look like the one below
Regards Keith....
Weebyx
Denmark
Posts 1,213
Weebyx replied on Sun, Aug 2 2020 8:04 PM
Keith Saunders:
Yes, but with orange edge. There is 10mm between the 2 legs on same side, and battery is 25x25mm in size.
/Weebyx
Keith Saunders
Posts 5,495
It is a Battery Lithium CR2430 3V 270mAh UL and when it says "specially adapted version" it means the legs were added.
I do not know the meaning of the orange edge, if it does have a meaning..
Regards Keith....
Keith Saunders
Posts 5,495
Weebyx:
Keith Saunders:
/Weebyx
It has a B&O part number of 8700027
Regards Keith....
Weebyx
Denmark
Posts 1,213
Weebyx replied on Sun, Aug 2 2020 9:54 PM
Keith Saunders:
Weebyx:
Keith Saunders:
/Weebyx
Yes, but dealers in DK will not sell spare parts :(
/Jacob
Weebyx
Denmark
Posts 1,213
Weebyx replied on Mon, Aug 3 2020 10:36 AM
Keith Saunders:
Weebyx:
Keith Saunders:
/Weebyx
I seem to have found a suitable battery :)
https://elektronik-lavpris.dk/p89541/cr2430slf-cr2430-240x30mm-lodret-3v-280mah/
/Jacob
Keith Saunders
Posts 5,495
Weebyx:
Keith Saunders:
Weebyx:
Keith Saunders:
/Weebyx
/Jacob
Well done, that is excellent news which others may wish to take note about for future use.. Thank you..
Regards Keith....
Weebyx
Denmark
Posts 1,213
Weebyx replied on Fri, Aug 7 2020 11:44 AM
Keith Saunders:
Weebyx:
Keith Saunders:
Weebyx:
Keith Saunders:
/Weebyx
/Jacob
Yes, this battery fits 100%, and it is easy to solder out the old and insert the new :)
I have replaced my old orange battery with this blue, and you were correct, in that the old states CR2430 3v, just like then new.
I have no idea what this colour indication is all about :)
Beosound 9000 works just like before, and funny thing is, that it remembered the time during the short period of battery change, had no radio stations stored, so I could not test if these were remembered also.
/Weebyx
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Aug 7 2020 12:03 PM
The coloured edge is just an isolation. It’s positive charged at the edge.
Page 1 of 1 (10 items) | RSS
