Update Bluray-Player of BV 7-40 3D
This post has 5 Replies | 2 Followers
Raeuber
Germany
Posts 2,542
Raeuber Posted: Fri, Mar 16 2012 1:32 PM
Hello,
I have connected my BV 7-40 3D with the internet and the software-update menue of the bluray player shows there is an update available (Vers. BODTBB47). But if I press the green key to start the update nothing happens and the BV 7 doesn´t react on any command of Beo 4! I have to disconnect and reconnect the BV 7-40 from/to the mains.
/Räuber
BEOCET
Posts 8
Silver Member
BEOCET replied on Fri, Mar 16 2012 2:51 PM
You have to press the Green key twice :)
Regards
Christian
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Mar 16 2012 3:04 PM
BEOCET:
Regards
Christian
Sorry Christian, but that doesn´t work too.
I have a Beo 4 without navy button. Probably I have to press another key combination!?
Regards
Räuber
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Mar 17 2012 1:23 PM
I tried the update again this morning and now it worked (the green key had to press twice)! Probably a problem with the network before.
I have discovered a new point in the advanced settings: DRC (OFF, ON and AUTO). Anybody knows this function?
Regards
Räuber
Flappo
Posts 850
Flappo replied on Wed, Apr 25 2012 8:50 AM
Raeuber - could you tell me if the bv7 3d has an ethernet port for the internet as the info on the b&o site only shows it for the 7-55 ?
How do you connect it to the internet ??
Thx in advance
Raeuber
Germany
Posts 2,542
Raeuber replied on Wed, Apr 25 2012 9:12 AM
Flappo:
Thx in advance
Hi Flappo,
yes, the BV 7-40 3D with the internal bluray player has also an ethernet port for the internet. I use this device to connect it with the internet:
http://www.amazon.de/gp/product/B003D0WZKC/ref=oh_details_o02_s00_i01
Regards
Räuber
Page 1 of 1 (6 items) | RSS
