Hello,
I have connected my BV 7-40 3D with the internet and the software-update menue of the bluray player shows there is an update available (Vers. BODTBB47). But if I press the green key to start the update nothing happens and the BV 7 doesn´t react on any command of Beo 4! I have to disconnect and reconnect the BV 7-40 from/to the mains.
/Räuber
You have to press the Green key twice :)
Regards
Christian
BEOCET: You have to press the Green key twice :) Regards Christian
Sorry Christian, but that doesn´t work too.
I have a Beo 4 without navy button. Probably I have to press another key combination!?
Räuber
I tried the update again this morning and now it worked (the green key had to press twice)! Probably a problem with the network before.
I have discovered a new point in the advanced settings: DRC (OFF, ON and AUTO). Anybody knows this function?
Raeuber - could you tell me if the bv7 3d has an ethernet port for the internet as the info on the b&o site only shows it for the 7-55 ?
How do you connect it to the internet ??
Thx in advance
Flappo: Raeuber - could you tell me if the bv7 3d has an ethernet port for the internet as the info on the b&o site only shows it for the 7-55 ? How do you connect it to the internet ?? Thx in advance
Hi Flappo,
yes, the BV 7-40 3D with the internal bluray player has also an ethernet port for the internet. I use this device to connect it with the internet:
http://www.amazon.de/gp/product/B003D0WZKC/ref=oh_details_o02_s00_i01
