How to wire an LC1
This post has 9 Replies | 1 Follower
a2bur
England
Posts 40
a2bur Posted: Mon, Jan 20 2014 8:50 AM
Normal 0 false false false MicrosoftInternetExplorer4
Hi . I’ve' acquired three LC1's and an having difficulty finding out how to wire them into my lamps , noting in the user guide ( says refer to a B&o service agent  )  Think I've attached a picture and sketch ( difficult to photo so have sketched )
Says B&o 800144 printed on the circuit board
Terminal P2  =   arrow pointing at it will a ‘  L
Terminal P3  =   arrow with a letter ‘  E    ( think its’ an E )
Terminal P4  =   no arrow , no letter
Terminal P5  =   arrow pointing at it with a letter     N
On the bottom plate =
1988 Bang and Olufsen
40-300 W
TYPE 2112    220 – 240 V   50 – 60 Hz
Serial numbers
No 091/04/B
No 08947815
No 07942975
Stonk
Marlow, Bucks, UK
Posts 2,070
Stonk replied on Mon, Jan 20 2014 12:51 PM
I had a diagram somewhere but can't find it at the moment. In the meantime THIS might help.
If you think nobody cares, try missing a couple of payments.
a2bur
England
Posts 40
a2bur replied on Mon, Jan 20 2014 1:22 PM
Hi Stonk . Thanks for the link , I can see why my dealer was reluctant to say without seeing them ,    doesn’t follow logic as I have an ‘ L ‘ pointing at P2 , an ‘ E ‘ pointing at P3 , an ‘  N  ‘ pointing at P5 , and nothing next to P4 , unless it the translation from Danish . Richard
Stonk
Marlow, Bucks, UK
Posts 2,070
Stonk replied on Mon, Jan 20 2014 4:08 PM
Hi Richard,
I haven't seen one for years but you are correct, it doesn't follow UK logic. E can't refer to EARTH as the unit is only fed by a live and neutral.
Steve
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Mon, Jan 20 2014 5:14 PM
Brengen & Ophalen
a2bur
England
Posts 40
a2bur replied on Mon, Jan 20 2014 5:33 PM
Hi and thanks , but what is L and N , is P3 or P4 the live . Richard
Leslie
Posts 5,423
Silver Member
Leslie replied on Mon, Jan 20 2014 5:40 PM
In my country that doesn't matter since you can put in the plug both ways into the outlet socket
Brengen & Ophalen
a2bur
England
Posts 40
a2bur replied on Mon, Jan 20 2014 5:57 PM
Hi . I realised that after I posted ( I must be a bit dim today ) but thinking I have Es bulb holders so did'nt want the outer part live , preffer the centre contact to be the live  . Richard .
Leslie
Posts 5,423
Silver Member
Leslie replied on Mon, Jan 20 2014 6:19 PM
Good thinking Richard, be carefull!
Brengen & Ophalen
a2bur
England
Posts 40
a2bur replied on Tue, Jan 21 2014 8:36 AM
Thanks for the help , all three working , though I had a problem at first as they seam to need 10 or 20 seconds to boot up before they will work , also got some LC2's but prefer these for table lamps as they stand better . Thanks again , Richard
Page 1 of 1 (10 items) | RSS
