Normal 0 false false false MicrosoftInternetExplorer4
Hi . I’ve' acquired three LC1's and an having difficulty finding out how to wire them into my lamps , noting in the user guide ( says refer to a B&o service agent ) Think I've attached a picture and sketch ( difficult to photo so have sketched )
Says B&o 800144 printed on the circuit board
Terminal P2 = arrow pointing at it will a ‘ L ‘
Terminal P3 = arrow with a letter ‘ E ‘ ( think its’ an E )
Terminal P4 = no arrow , no letter
Terminal P5 = arrow pointing at it with a letter ‘ N ‘
On the bottom plate =
1988 Bang and Olufsen
40-300 W
TYPE 2112 220 – 240 V 50 – 60 Hz
Serial numbers
No 091/04/B
No 08947815
No 07942975
I had a diagram somewhere but can't find it at the moment. In the meantime THIS might help.
If you think nobody cares, try missing a couple of payments.
Hi Stonk . Thanks for the link , I can see why my dealer was reluctant to say without seeing them , doesn’t follow logic as I have an ‘ L ‘ pointing at P2 , an ‘ E ‘ pointing at P3 , an ‘ N ‘ pointing at P5 , and nothing next to P4 , unless it the translation from Danish . Richard
Hi Richard,
I haven't seen one for years but you are correct, it doesn't follow UK logic. E can't refer to EARTH as the unit is only fed by a live and neutral.
Steve
Brengen & Ophalen
Hi and thanks , but what is L and N , is P3 or P4 the live . Richard
In my country that doesn't matter since you can put in the plug both ways into the outlet socket
Hi . I realised that after I posted ( I must be a bit dim today ) but thinking I have Es bulb holders so did'nt want the outer part live , preffer the centre contact to be the live . Richard .
Good thinking Richard, be carefull!
Thanks for the help , all three working , though I had a problem at first as they seam to need 10 or 20 seconds to boot up before they will work , also got some LC2's but prefer these for table lamps as they stand better . Thanks again , Richard
