Beogram 5005 - Wobble when arm returns to rest position
This post has 9 Replies | 0 Followers
Lee
Newcastle upon Tyne UK
Posts 734
Lee Posted: Fri, Dec 13 2013 7:41 PM
Hi everyone,
My Beogram 5005 seems to have developed a strange issue, the tonearm does a little wobble when it returns to the rest position. It doesn't do it if the record plays from start to finish and returns on its own, but if I stop a record half way through it does.
I've uploaded a video to youtube of the problem, please take a look and have a listen - http://www.youtube.com/watch?v=bykosfHl4Zc
Any Ideas guys? Is it supposed to do that?
Thanks in advance,
Lee
Lee
Posts 734
Lee replied on Wed, Feb 19 2014 4:01 AM
Just bumping my post which I've now edited to include a link to a video of the problem...
Any Ideas guys?
Lee
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Feb 19 2014 3:53 PM
Check the grease on the carriage rails. It can dry and become sticky, causing something like this.
Lee
Posts 734
Lee replied on Wed, Feb 19 2014 6:16 PM
Hi Martin,
I'm going to re-grease the rails and see if this fixes the problem.
I have a tub of molly kote grease, some white lithium grease, and a tin of servisol 70 silicone spray grease, are any of these suitable?
Thanks,
Lee
Dillen
Posts 13,191
Dillen replied on Wed, Feb 19 2014 6:30 PM
You will find remains of white grease in there.
I suggest you use that again.
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Feb 19 2014 6:54 PM
I use Robbe teflon grease.
Jacques
Lee
Posts 734
Lee replied on Wed, Feb 19 2014 7:25 PM
Dillen:
Would that be white lithium grease Martin?
Dillen
Posts 13,191
Dillen replied on Wed, Feb 19 2014 7:45 PM
Yes, it's used because of the carriage (nylon'ish plastic) material.
Lee
Posts 734
Lee replied on Wed, Feb 19 2014 8:30 PM
Just checked the white lithium grease I've got and its marine grade so I'm a bit sceptical about using it... not sure if being marine grade it contains some additives that would damage/soften the plastic carriage. Any one any ideas?
Thanks again,
Lee
Dillen
Posts 13,191
Dillen replied on Wed, Feb 19 2014 8:43 PM
I don't think it will cause any damage but you can use almost any non-acid grease.
Silicon grease will also work.
Page 1 of 1 (10 items) | RSS
